Formlabs Developers
Download PreForm Insider to start developing with the PreForm API.
Version v1.0.0-alpha (latest)
Server Info
Endpoint for checking that the server is up and reachable.
Get server version#
GET/v1/
Returns the version of the running PreFormServer instance. Does not require a request body or authentication. Use it to confirm the server is up and reachable before issuing other requests.
Returnsobject
  • versionstringRequired
    The running PreFormServer's version string.
The server responded successfully.
GET/v1/
Python
from formlabs_sdk import FormlabsClient
with FormlabsClient() as client:
    preform = client.preform.connect()
    result = preform.get_server_version()
Terminal
curl "http://localhost:44388/v1/"
Response
JSON
  "version": "1.0.0"
