Formlabs Developers
Download PreForm Insider to start developing with the PreForm API.
Dashboard client
A Dashboard client calls the Formlabs Web API, the API behind Dashboard, at https://api.formlabs.com/developer/v1/. It reads the same printers, print history, Printer Groups, and group queues that Dashboard shows, so a script can build a usage report across every printer on the account.
The SDK has no methods for the Formlabs Web API endpoints, so the client has two parts. A FormlabsClient with developer credentials supplies the token, and an HTTP client sends the requests. To send a print job to a group queue, as Upload to Queue does, use the PreForm client. For more information, see PreForm client.
What each part does#
The two parts split the work:
  • FormlabsClient: Holds the client ID and client secret, requests the developer token, caches it, and requests a new one 300 seconds before it expires. Closing the client revokes the token.
  • HTTP client: Sends each request with the token in the Authorization header. The examples on this page use httpx, which the SDK installs.
To create the client ID and client secret in Dashboard, see Install the Developer Kit.
Attach the token to each request#
An httpx.Auth class asks the session for the token on every request, so a refreshed token reaches the next request:
Python
class DeveloperTokenAuth(httpx.Auth):
    """Adds the developer token to each request, and retries once after a 401."""
    def __init__(self, session):
        self.session = session
    def auth_flow(self, request):
        # The session returns its cached token until 300 seconds before it expires.
        request.headers["Authorization"] = f"Bearer {self.session.developer_token()}"
        response = yield request
        if response.status_code == 401:
            # The server revoked the token. Drop it so the session mints a new one.
            self.session.invalidate(TokenKind.DEVELOPER)
            token = self.session.developer_token()
            request.headers["Authorization"] = f"Bearer {token}"
            yield request
A 401 response means the server rejected a token the session considers valid, for example after the token was revoked. The invalidate method drops the cached token, and the retry carries a new one.
Create the client#
The HTTP client takes the Formlabs Web API base URL and the auth class:
Python
credentials = FormlabsCredentials(
    client_id=os.environ["FORMLABS_CLIENT_ID"],
    client_secret=os.environ["FORMLABS_CLIENT_SECRET"],
with FormlabsClient(credentials=credentials) as client:
    # Closing the client revokes the developer token, so every request runs inside
    # this with block.
    with httpx.Client(
        base_url="https://api.formlabs.com/developer/v1/",
        auth=DeveloperTokenAuth(client.auth),
    ) as dashboard:
Creating FormlabsClient makes no network request. A rejected client ID or secret raises InvalidCredentialsError on the first request, when the session requests the token.
Send a request#
Paths are relative to the base URL:
Python
response = dashboard.get("printers/")
response.raise_for_status()
for printer in response.json():
    print(printer["serial"])
The printers/ endpoint returns every printer on the account. Some list endpoints wrap their items in an envelope with count and results. For more information, see the Formlabs Web API reference.
What the Formlabs Web API covers#
The Formlabs Web API reads and manages what Dashboard shows:
AreaPaths
Printersprinters/, printers/{printer_serial}/
Print historyprints/, printers/{printer_serial}/prints/
Printer Groups and group queuesgroups/, groups/{group_id}/members/, groups/{group_id}/queue/
Consumablescartridges/, tanks/
Eventsevents/
For every endpoint, see the Formlabs Web API reference.
What's next#
